This command allows to you configure the port that will be the slave-port when BMCA is off. All other enabled network gPTP ports will be master ports.
| network-clock | Network Clock |
| gptp | Variable description, available options, and notes. |
| slave-port | Configure slave port when Best Master Clock Algorithm is off. |
| port_no | Port Number of slave port |
| none | This switch is the Grand Master Clock (GMC). |
N/A.
Use this command to you configure the port that will be the slave-port when BMCA is off. All other enabled network gPTP ports will be master ports.
The following example shows the output of the show network-clock gptp command with BMCA.
gPTP status         : Enabled
BMCA                : [On | Off]
Static slave port   : 5 (used when BMCA Off)
--or--
Static slave port   : None (used when BMCA Off)
gPTP enabled ports  : *1m     *21d    *22d    *47d
Flags:        (*) Active,  (!) Administratively disabled,
              (d) Disabled gPTP port role, (m) Master gPTP port role,
              (p) Passive gPTP port role,  (s) Slave gPTP port role
    This command was first available in ExtremeXOS 15.7.
This command is available on platforms that support the AVB feature pack license and have it installed. For complete information about software licensing, including how to obtain and upgrade your license, and which platforms support the AVB feature, see the Switch Engine v33.1.1 Licensing Guide document.
